Touch and Go Functionality
http://forums.skydemon.aero/Topic34549.aspx
By Still_Learning - 1/29/2022 1:10:38 PM
Hi
Having flown a couple of flights recently with a T&G at various fields, it would have helped a lot to have the ability to add a Touch & Go into a flightplan.  Looking through the forum a number of workarounds exist - either "Land Here", but then you effectively have 2 flights which are not well stitched together - separate PLOGS and I assume separate Flightplans; alternatively manually add circuit-waypoints to the T&G field which again is very much a workaround.
I'm sure there's loads of complexity in including this into the flightplan, but would be very useful and make the flight planning process a great deal slicker.
Cheers
Andrew
