SkyDemon on Android 11 losing GPS signal when device locks
aplatte
a
Posts: 2, Visits: 0
After moving from Android 7 to Android 11, I have noticed SkyDemon looses GPS signal when the device locks (i.e.: you want to try to navigate on your own, and have SD as backup just in case you get lost). When you unlock the device, SkyDemon starts getting GPS signal again, and you lost the flight log during the screen lock.
When checking permissions, I can only give SkyDemon one of the following for location: "Allow when app is running", "Ask" or "Don't allow". I see other apps (i.e.: Google, AccuWeather) have an extra option "Allow always", which I cannot choose for SkyDemon.
I suspect this article explains the reason: for Android 10 and above the app should declare ACCESS_BACKGROUND_LOCATION permission in its manifest.
Can anyone else running SkyDemon on Android 11 tell me if they experience the same behaviour?
Thanks, and best regards,
Adrian
Edited 1/9/2022 5:52:58 PM by aplatte
Adam Erchegyi
Adam Erchegyi
Posts: 108, Visits: 2.3K
aplatte - 1/9/2022 5:24:04 PM
Adrian
Did you try to turn off battery optimization?
"Allow always" is for apps that need to start and monitor your location with you being unaware they're doing it. SkyDemon is not such an app. As long as you start navigating in SkyDemon, you are free to use other apps and SkyDemon will continue to receive your location, which is how it's designed to work. Locking your device should also work, but it's possible there are device-specific issues that might stop it.
Android 11 is a popular operating system and SkyDemon is a popular product, we're unaware of any general issues with SkyDemon running in the background on it.
aplatte
a
Posts: 2, Visits: 0
Adam Erchegyi - 1/9/2022 6:52:23 PM
Adrian
That was causing the issue. Disabling it did the trick.
Thanks a lot, Adam.
177
1
Posts: 72, Visits: 757
You can also download free 'GPS Locker' from Google Play. It will keep awake the gps chip no matter what.
