New aircraft profile: help please
Freccia
F
Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)
Posts: 30, Visits: 162
Hi, I would like to create a profile for the Bristell Classic airplane (BRISTELL UL HD with ROTAX 912 ULS engine). In your opinion which aircraft - among those available in SkyDemon - is closest?
Thanks.
Gerhard66
G
Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)
Posts: 173, Visits: 358
Freccia - 11/28/2021 10:05:33 AM
Thanks.
Hi Freccia,
from my personal experience i would strongly recommend to start with an empty profile and go through all available entry fields.
If you use an existing profile, you anyway have to check all fields to make sure, your profile fits your aircraft.
With a good profile, based on your POH, SD's fuel calculations are incredibly precise!
I know, this answer will not help you very much ;-) but it is the only way to get good calculations from SD.
Gerhard
Freccia
F
Gerhard66 - 11/28/2021 12:56:05 PM
Thanks.
Hi Freccia,
Gerhard
Hi Gerhard,
thanks for your help but I wrote this question because I haven't found a way to create an empty profile. SD only allows me to modify one that looks like my airplane
Gerhard66
G
Freccia - 11/28/2021 4:51:59 PM
Thanks.
Hi Freccia,
Gerhard
Hi Gerhard,
Oh sorry, I created my profiles some years ago and told you nonsense ;-)
I guess it does not matter from which default aircraft you start, as you have to check all entry fields thoroughly. I’m sure, you cannot let even one of the fields unchanged…
SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)SkyDemon Team (693K reputation)
Posts: 8.2K, Visits: 9.8K
There's no such thing as an empty aircraft profile in SkyDemon. What we used to offer to start with was a Piper PA28.
