Choosing Android Tablet
1
Posts: 72, Visits: 757
You may want to give a look at Alldocube iPlay 40 on Aliexpress. For the price of Apple pencil you will get a real snappy tablet with 8 gigs of RAM, 128GB storage and very bright (I think it's over 400 nit) and vivid IPS display. It runs YouTube 4k vids without stuttering.
The tablet has some old navigation chip (gps-only), but I personally don't use built-in navigation anymore and I recommend you to build a Stratux EU to receive/transmit traffic information and get a reliable position indication as well (via ublox M8N chip).
Edited 11/20/2021 4:40:15 PM by 177
diogofcr
d
Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)Too Much Forum (164 reputation)
Posts: 8, Visits: 0
Johannes B. - 11/20/2021 1:24:05 PM
I just opted for the Samsung Tab 3 Actice, which is the best Android tablet for this purpose at the moment.
Rugged and waterproof, quick hardware, Android 12 ready, pen and case included, great size (8") and bright screen... with exchangeable battery...
Nice! I will have a look. Thank you
Johannes B.
J
Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)
Posts: 54, Visits: 1
diogofcr - 11/25/2021 1:13:18 PM
It us much more expensive than what you were looking for, but tablets for 200 Euro are too slow for smooth planning operation and the screens are mostly not suitable for bright sunlight ops.
YouTube channel
Csongor
C
Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)Too Much Forum (154 reputation)
Posts: 4, Visits: 7
KimW - 11/18/2021 9:11:40 PM
I use Lenovo M8. Perfect size, very long battery life (have seen +7 hours flight time with SD without needing external power source) and low price on the plus side. A bit slow for planning in the device, but have had no issues in flight using internal GPS.  Use my phone as hotspot to get data access on ground and if needed in air.
I have looked at iPad but just don't find price value reasonable and seems there is issues with battery life and overheating, as high performance in small formfactor has it's drawbacks.
Hope you find what works for you.
+1
I'm also using a Lenovo Tab M8 FHD and it's a great little tablet for a reasonable price. Almost the same size as an iPad mini, so it will fit in most of the holders and cradles made for the iPad.
RainerM
R
Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)Too Much Forum (858 reputation)
Posts: 26, Visits: 185
I bought a Huawei T3 and a 128M memory card.
The problem is that Huawei does NOT combine the internal and memory card storage into one.
This means that I always have little storage space, because SkyDemon can only use the internal memory.
And that is also used by other applications.
So I would definitely NOT recommend using Huawei.
177
1
177 - 11/20/2021 4:28:11 PM
Correction to my previous. Yesterday I had some spare time to play with settings. The tablet actually has modern GNSS chip that can run on 4 different satellite constellations (3 at a time via the *#*#2266#*#* engineering menu): GPS, GLONASS, Galileo and BeiDou.
You won't find anything better for 150EUR.
RogerWilco77
R
Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)
Posts: 1, Visits: 11
I have a Samsung Galaxy Tab S7 witch runs really nice with SD, however, the size at 10" is too large for many planes.
I use my Samsun Note 10+ in a ram mount holder in the cockpit. However, it is actually too small.
I am looking for something in between, probably 8".
Perhaps it would make sense if there was a table on experiences which tablet runs smoothly (with bright enough display) with Android and SD version?
I am afraid that a tablet that was ok 2 years ago might be outdated soon. Also except for apple, there seem to be no new products since 2020.
KimW
K
Posts: 59, Visits: 0
After trying 3 Android tablets I finally found one I really like.
Lenovo M8 - perfect size, long battery life, perform fine in flight. Is frustratingly under powered and slow.
Samsung A7 Lite - A bit too large and almost as under powered as the Lenovo. Thought it would be a great upgrade, but used it for 2 flights and went back to my M8.
ALLDOCUBE iPlay50 Mini Pro - Almost same size as M8, but massively more power and I now enjoy doing planning on it. Also have a SIM card option.
I turn off all factory loaded stuff to make sure only my Aviation apps are installed, to have a nice and clean tablet setup.
andi
a
Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)
Posts: 4, Visits: 2
i will try the new Xiaomi Redmi pad 8.7 with 4g
it has a good battery and a lcd with 600nits
but Performance could be better for other applications than skydemon but i guess its not soo bad.
fruitloops101
fruitloops101
Posts: 38, Visits: 147
diogofcr - 11/17/2021 6:21:44 PM
Hi everybody, I wanna start using Sky Demon and I need a new tablet. I wanna know what to buy.
I know the ipad is probably the best choice, my problem is the price....
I need one with GPS (ofc) and 200 euros max. Can you please help?
Nokia T10.
Using an external GPS via WiFi (SkyEcho 2) and having removed all the bloatware I can get 4 hours at full screen brightness and only use less than 50% of the battery. It's not the most fantastic tablet but for just over €100 it's more than adequate for SkyDemon and it has never let me down.
