How to export Part-FCL-compliant logbook to a CSV file? ...and import?
How to export Part-FCL-compliant logbook to a CSV file? ...and import?...
Daniel Arnold
D
Posts: 1, Visits: 0
Wouldn't it be great if the "update logbook" could be exported into a CSV-file for reason of personal record?  And I have older logbook data in CSV-files before I started Skydemon subscription: it would be great to import these data to a single Skydemon logbook.
You can export flight logs via "view all flight times" but not for the Part-FCL-compliant logbook.
Has anyone experience with that topic?
We do plan on adding an export capability in the next few months, likely to CSV.
Import is somewhat different, and we do not currently plan this.
Andrew
A
Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)Too Much Forum (474 reputation)
Posts: 28, Visits: 88
Hi Tim
Was renewing my PPL and needed a 12-month summary by aircraft type in a specific format.  Any chance you've had a chance to look at the export to CSV functionality - then I can easily set up a template in Excel to pull the info into?
Cheers
Andrew
We haven't, and the best reason I can offer for this is that very few people have asked for it so other things have taken priority. Did you have any requirements other than (presumably) all columns simply being output in a known format?
Andrew
A
Tim Dawson - 4/19/2022 9:34:45 AM
I guess all columns would do the trick as it would require less dev than having to store user prefs for the specific columns they each need - a csv can be easily manipulated as needed, pivot ed, etc
We've implemented an Export CSV option in the digital logbook, you can try it now.
Andrew
A
Tim Dawson - 5/12/2022 11:34:32 AM
Thanks Tim - works like a bomb!
