EDCJ Traffic Pattern in SD map
matt407
m
Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)Too Much Forum (299 reputation)
Posts: 4, Visits: 76
the traffic pattern of EDCJ is not shown in the map - could you check that? (iPad, latest SD version in use)
Thank you.
Best Regards,
Matt
Edited 10/12/2020 8:01:14 AM by matt407
Yes, it's deliberately excluded at the moment because the current approach chart from DFS is incorrect in its depiction of the runways. It is therefore not clear where the circuit actually goes. I believe we are following this up, but I will check.
pilot-byom
p
Posts: 323, Visits: 388
The last published traffic pattern is only off by a little degree, so I woould say that does not really qualify as ‚wrong‘.
If you correctly georeference the plate, it shows the runways being at least 20 degrees out of their true orientation. Since the circuits project from the runways it's by no means clear what is correct, which is why we are looking into it and not depicting them in SkyDemon at the moment.
matt407
m
is there any update on this?
Regards,
Matt
There hasn't been a new plate issued. We will chase the DFS again.
pilot-byom
p
Tim Dawson - 3/5/2021 9:58:05 AM
The DFS appears to not really be an active player in that game, they only collect and distribute - my understanding of PTFE. If you long for a solution you may have to talk to the airfield directly or hope somebody at DFS has a nice day and does it for you. So my understanding of the German structure and past experience with DFS on who has which obligation.
Edited 3/5/2021 10:37:09 AM by pilot-byom
