No english voice was found on your device so speech will not be available.
Selev
S
Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)
Posts: 4, Visits: 3
Hi everyone.The problem i have has occurred before and has been posted on these forums:
It relates to the voice files on an ANDROID device not being loaded, and so i do not get any verbal warnings as it appears that the the speech to text app does not load up on SKYDEMON, instead you get the following warning: No english voice was found on your device so speech will not be available
This is not a SKYDEMON fault, it is down to ANDROID.
I ask on this forum as i hope someone out there has had the problem before and knows of a fix.
As per the link above i have the relevant speech to text app installed, and all the relevant updates are installed on the device, also SKYDEMON is set up for verbal traffic warnings and everything is as it should be.
Many thanks in anticipation.
Selev - 9/24/2020 6:51:53 PM
Make sure that you have selected a voice – Navigation Options > Speech > Voice
6575, SD 4.2.2
Selev
S
Posts: 4, Visits: 3
Sky Painter - 9/25/2020 11:44:52 AM
Thanks Mike, I saw your reply in the linked forum. This seems to have been rectified, for info of anyone having the same problem,I had to do a factory reset on the phone which after restart has restored the files.
Daniel Biton
Daniel Biton
Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)Too Much Forum (262 reputation)
Posts: 25, Visits: 377
Good afternoon, I got also the same problem.
Reseting the tablet was not what I wanted.
It turned out the solution for me was a little bit different.
On the tablet, starting at the main menu:
<Settings>
   <Accessibility>
        <Screen readers>
on my tablet, that was empty.
I had to fix it with:
             <Text to-speech outpout>
                    <Preferred engine>    for which I choosed SpeechService by Google
Now it works correctly now and I am very happy.
Dan.
