Connection with AIR Traffic AT-1
Martin Baumruk
M
Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)
Posts: 2, Visits: 1
Do You have experience with connecting of SkyDemon to AIR Traffic AT-1 for traffic avoidance? I tried to set several protocols via wifi (air connect etc.), but I always get only external GPS data to SkyDemon and I never see any traffic data during a flight. Which setting do You use for SkyDemon and for AT-1 exactly?
Thanks a lot.
SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)SkyDemon Team (694K reputation)
Posts: 8.2K, Visits: 9.8K
You might try contacting customer support with this one.
Peter Baier
Peter Baier
Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)Too Much Forum (98 reputation)
Posts: 9, Visits: 10
Martin Baumruk - 7/4/2020 7:48:27 AM
Thanks a lot.
Martin,
we had the same problem, SD support could not really answer the question but transferred us to AT support. Their answer was swift: Configure AT-1 on its config page to transmit on WIFI the GDL90 protocol (WIFI must be set to Permanently ON and the WIFI data output must also be set to ON), don't forget to safe your changes.
Then in SD, when in Flying Mode, select under Connectivity also the GDL90 interface and it should work now.
Happy landings
Peter
Martin Baumruk
M
Posts: 2, Visits: 1
Peter Baier - 8/17/2020 4:37:06 PM
Thanks a lot.
Martin,
Happy landings
Peter
Hello Peter,
thank You for Your answer. Actually, I had managed to connect it later by the same way, as You decribed. The only problem is, that a) the wifi connection to AT-1 causes, that I loose my cell phone signal and I cannot get any call or use internet during the flight (weather etc.) and b) the use of AT-1 GPS is not stable. I loose my position for example for 20 seconds, which is quite incovinient.
So although the connection is working now through GDL90 interface, I rather do not use it...
But thank You anyway.
Martin
I believe the product in question also supports using the Flarm protocol, have you tried switching to that?
jiaolong
j
Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)Too Much Forum (65 reputation)
Posts: 7, Visits: 30
Hi all
Thanks, I will try next time the GDL90 protocol.
Will write a feedback here after I tested it for a while.
Stay healthy!
Alain
