Customized Overlays for Charts
markusL
m
Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)
Posts: 3, Visits: 0
I hope I didn´t oversee something and sorry if this has already been discussed. It would be nice to have an option to create customized map overlays not only for waypoints also for special routes and areas. At some airports, there are noise-sensitive areas and they have special VFR departure or arrival routes for example to the reporting points but not published in the AIPs or charts. It would be great if there is a possibility to create customized overlays to mark areas and draw routes and put this as an overlay on top of the moving map.
Posts: 659, Visits: 32K
markusL - 6/20/2020 1:47:17 PM
Check out the custom data tool on the Windows version. Create your objects on Windows then share to your mobile devices via the cloud.
markusL
m
Posts: 3, Visits: 0
grahamb - 6/20/2020 2:23:59 PM
Is there a possibility to turn on a photorealistic background image to have references? It´s just a blank very rudimental map and in case there are no GPS references available? Or must I find first all the positions in Google and then manually transfer it into the Editor?
Have you not seen the Aerial Photography feature on the What’s Here pop-up?
markusL
m
Posts: 3, Visits: 0
grahamb - 6/20/2020 4:59:41 PM
This is all what I see in the Airspace Editor tool.
markusL - 6/20/2020 5:31:05 PM
Sorry, I meant to use the Aerial Photography feature in the main chart to identify your points and get the Lat/Long, then copy them to the tool.
Not ideal, but doable.
