Huawei P30 / XGPS160 mock GPS provider issue with SD
Clearofcloud
Clearofcloud
Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)Too Much Forum (424 reputation)
Posts: 6, Visits: 18
Hi All,
I recently changed phone to the Huawei P30 and have run into an issue.
Skydemon won't recognise the bluetooth gps signal from the XGPS160, which it has recognised before on my Samsung S6
Here's my setup
Huawei P30
XGPS160
Skydemon
BluetoothGPS (software mock GPS provider)
I've updated the SD software, updated the firmware on the XGPS160 and ensured "mock location" is allowed in the Developer options of the phone.
The phone will connect to the GPS and receive data successfully: the BluetoothGPS software confirms this.
When I try to "Go Fly" in SD, Skydemon tells me I have to enable location services, which then uses the internal phone GPS rather than the XGPS160
Anyone have any suggestions
I'm curious to know why you would want to use an external GPS source when your phone has an internal GPS.
26200.7840, SD 4.2.3
Clearofcloud
Clearofcloud
Battery management and I can leave phone in flight bag without loss of signal.
Posts: 647, Visits: 31K
I know nothing about Huawei phones but it sounds to me like the XGPS160 isn't interacting with the location services function on the phone properly.
Clearofcloud
Clearofcloud
I'm not so sure that it's the physical GPS unit. The BluetoothGPS software is recognizing the hardware and it is appearing in Android's list of mock GPS providers. For some reason, SD is not getting the "mock signal".
The phyiscal hardware is definitely working on my old Ipad , which doesn't use mock proiders, so I'm reasonably confident that it is some sort of software issue.
