Baggage/ Lugage
elanbaby
e
Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)Too Much Forum (242 reputation)
Posts: 22, Visits: 0
just wondering why in w&b one aircraft model shows "Baggage" while another reads "Lugage"? Same device, same current SD version. Any idea?
Cheers,
Juergen
Edited 3/9/2020 9:21:31 AM by elanbaby
Posts: 657, Visits: 32K
elanbaby - 3/9/2020 8:36:23 AM
Cheers,
Juergen
Presumably because that is what the persons who created the aircraft models named them. It's up to the user what they call them.,
Look at 'Loading Points' in each of the aircraft definitions to see what they have been named.
Edited 3/9/2020 9:54:21 AM by grahamb
elanbaby
e
grahamb - 3/9/2020 9:53:23 AM
Cheers,
Juergen
The aircrafts are from SDs list. I can edit the data, but not "Passenger", "Pilot", "Baggage"...    as far as I tried
Edited 3/9/2020 1:51:51 PM by elanbaby
elanbaby - 3/9/2020 1:49:43 PM
Cheers,
Juergen
Are those aircraft models not crowdsourced from the user community?
The loading point names can be edited in the iOS and Windows versions, so I would be surprised if they can't be in the Android version.
Edited 3/9/2020 4:11:17 PM by grahamb
grahamb - 3/9/2020 3:15:27 PM
Cheers,
Juergen
Are those aircraft models not crowdsourced form the user community?
They can!
26200.7840, SD 4.2.3
elanbaby
e
Sky Painter - 3/9/2020 3:26:35 PM
Cheers,
Juergen
They can!
Oh! Thanks! I thought all the data is supplied by "Sky Demon" and thus would be sort of reliable...
No problem, I'll double check then and edit if necessary.
Cheers,
Juergen
Edited 3/9/2020 5:04:38 PM by elanbaby
Which aircraft model is this? I will check it. Though a lot of aircraft models are provided by owners, we carefully check through them all and I would be surprised if anything like this had got through.
Edited 3/10/2020 10:58:54 AM by Tim Dawson
elanbaby
e
Tim Dawson - 3/10/2020 10:58:26 AM
Thanks for your reply! Not really a factor as I made up my own aircraft setup.
Here's the one I talked about. Stumbled across the misspelling of "lugage" which sounded sort of french to my ears :-)
Cheers,
Juergen
Thanks. I can't actually see anything wrong with it except that we would have properly cased the loading point names.
