Rename user documents to associate them with airports?
pseudonym
pseudonym
Posts: 50, Visits: 189
Hello!
Is it feasible to rename user documents in order to have skydemon associate them to airfields according to the icao code?
Can a user specified waypoint of an airport not covered by SD (eg Senegal) and stored as ‚airport‘ be associed with such ICAO_doc documents?
Posts: 649, Visits: 31K
pseudonym - 12/10/2019 3:08:12 PM
Hello! Is it feasible to rename user documents in order to have skydemon associate them to airfields according to the icao code?Can a user specified waypoint of an airport not covered by SD (eg Senegal) and stored as ‚airport‘ be associed with such ICAO_doc documents?
From page 50 of the user manual:
To add one of your own PDFs to the list for a specific airfield, just make sure that the PDF’s filename begins with the airfield ICAO code or local identifier followed by an underscore, for example EGBK_filename.pdf, and the document will then be available alongside the other official plates when you open the Airfields tab and tap on the airfield in question.
efrenken
efrenken
Posts: 265, Visits: 3.5K
What is meant by ‘local identifier’? Can I associate a document to an airfield without ICAO designator?
Eric
