Weight and Balance
danGigantic
d
Posts: 6, Visits: 3
Version v3.12.13.0
I seem to be having an issue getting CofG to work as I would like please see attached a screenshot of SD and the paper version. Sadly, both very different from each other.
You're comparing a weight/moment graph in your PoH with a weight/CoG graph in SkyDemon. If your intention was to transcribe the graph into SkyDemon, you need to convert those units first.
Posts: 632, Visits: 31K
danGigantic - 11/18/2019 8:46:07 PM
Version v3.12.13.0
It looks to me like you are confusing the X-axis units.
The units in SD are distance from datum ('arm'), whereas those on your spreadsheet are moment, which is weight x arm.
(Edit - I see my post has crossed with Tim's!)
Edited 11/19/2019 10:48:16 AM by grahamb
danGigantic
d
Posts: 6, Visits: 3
Fantastic, thank you for clarifying my confusion. Thank you Tim and Graham for responding.
