SkyDemon Navigation
Aircraft Colour displayed - SkyDemon InFlight
fas3robinj
fas3robinj
posted 12/8/2009 11:14:37 AM
Visits: 9
On my Navigo the aircraft (showing current position) is yellow. This becomes difficult to see over and around built up areas. Can the colour of the aircraft be changed to say Green? Even black would be more visible.
Thanks ;-)
posted 12/8/2009 6:18:41 PM
Posts: 8.2K,
Visits: 9.7K
It's black on yellow. Does it look significantly different from the screenshot below?
http://www.skydemon.aero/inflight/screenshot.jpg
fas3robinj
fas3robinj
posted 12/9/2009 2:34:51 AM
Visits: 9
Tim, Yes all I see is a yellow aircraft. The aircraft appears solid yellow. Same colour as built up areas.
posted 12/10/2009 11:44:09 AM
Posts: 8.2K,
Visits: 9.7K
That's two drawing glitches you've described which seem only to manifest themselves on your specific hardware. This may mean we're unable to do anything to correct them. If possible could you take and post a photo of the screen, showing the incorrect drawing?
