Pilot Log Font Size
Flyingstevie
F
Posts: 2, Visits: 6
i use SD since many years, it's a great tool. I create all the flights with an iPad, because i have no PC (only a mac)
When i create a routing pack and send it to my email address and print it,  the font size in the flight log is very small.
The font size in fuel calculation an weight and balance calculation is OK.
Can i change the font size in the flight log area ?
You see a screenshot in the attachment.
Thanks for help
BriefingPack.pdf (777 views, 68.00 KB)
SkyDemon has had to reduce the font size in order to show all the columns you have selected for the PLOG. Try removing some columns and the font size should return to the same as used elsewhere.
Flyingstevie
F
Posts: 2, Visits: 6
Tim Dawson - 11/4/2019 10:49:24 AM
Thank you for the answer.
It´s possible to deselect the column MSA and the boxes Startup and Shutdown from the printed Flightlog ?
It would be great if there will be a empty box für the departure clearance as well as a box for a approach clearance.
Can i modify the print log my self ?
Thanks for the great Product
