Return to Planning mode
Posts: 365, Visits: 2.6K
After completing a flight and having landed, there is an option to select on the Virtual Radar to "return to planning mode".
I have tried this twice now but nothing happens when selecting the option.
Android version 3.12.10
Tony
Posts: 8.2K, Visits: 9.6K
Does exiting navigation mode from the in-flight dropdown work?
Tim,
I tried the dropdown and it works. However, I flew over the weekend and the virtual radar "return to planning mode " worked once.
On return to my home airfield it didn't work.
Tony
Raymond Osborne
R
Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)Junior Member (11 reputation)
Posts: 1, Visits: 0
I have had a similar problem since installing the latest update at the end of August. I use an iPad with built in gps and have done so for many years. On selecting "go flying" the green bar with "waiting for location data" comes up and then a couple of seconds later the correct position and height come up. However, after about 10 to 15 seconds the "waiting for location data" bar comes up again and the system freezes. Has anyone had a similar problem. My iPad has the latest system update and is obviously receiving gps information as it initialises properly before freezing. Any help would be appreciated.
Raymond, your query is unrelated to the subject under discussion and is probably that your iPad is wifi-only and does not contain a GPS. Feel free to start a new thread or contact technical support.
Tony, I've been trying to reproduce this here in the office but without success. Could you possibly contact technical support and give them a description of the problem including what device you're using, and whether you can reproduce the issue in simulator mode?
Will do.
hanks
Tony
