Suggestion for auto logging 'off blocks' time
vfr-uk
vfr-uk
Posts: 51, Visits: 81
Love the blocks feature and how once you've logged off blocks SD logs the on blocks automatically.
That said, would love the option to just set a preference ie  'auromatically log blocks times' and SD log both without any further input required. That way SD only needs to be put into flying mode and will log everything needed - for example if the device isn't to hand (or forget to press or whatever).
vfr-uk
vfr-uk
(Apologies if this should have been in the feature request section)
We do automatically log off blocks, as long as you've logged engine start. That way, SkyDemon knows you've just started the engine and are sitting stationary, and therefore it can reliably detect your first movement as moving off blocks.
vfr-uk
vfr-uk
Great, thanks, didn’t know that - will use that technique.
Usually try not be looking at a device at engine start but will try and get into habit of doing it prior.
