How to Change the RWY in Use?
airborne
airborne
Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)Too Much Forum (496 reputation)
Posts: 24, Visits: 36
SkyDemon shows a small window with the RWY in use in the lower right corner. How can the RWY be changed? (And how is the RWY shown in the first place?)
Gerhard66
G
Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)
Posts: 175, Visits: 358
Tap on the small window and „Cancel approach“
airborne
airborne
Gerhard66 - 3/3/2019 10:11:48 AM
The only option available is 'Information', probably because I am not referring to an approach situation.
Posts: 663, Visits: 32K
airborne - 3/3/2019 10:39:12 AM
Which OS and version of SD are you using?
If you're on the ground, SkyDemon will just be showing you the details for the nearest runway.
airborne
airborne
Thanks, Tim, is it possible to change the runway details shown, i.e., to let SkyDemon show the details for another runway?
No. That little picture is just there for convenience; if you want the details for a different runway simply tap there, open the full Airfield tab and all runway information is available under Approach Information.
