Charts and Aeronautical Data
How to insert custom routers?
kakugo
kakugo
posted 2/20/2019 11:13:08 AM
Visits: 72
I'm playing with the SkyDemon Data Creator and I'd like to know exactly which format to use to paste a custom route definition into the Airway Editor.
Using a sequence of space separated coordinates works, but it does not set any vertical limits or width; how can one do that?
I have another question: in one of my tests I used as waypoint in a route definition the coordinates of a custom waypoint I had defined earlier; I then correctly found the identifier of the waypoint under the "Waypoint" column of the Airway definition.
Is the identifier found by looking for a waypoint with the exact same coordinates as the position given, or there is a margin of error? If so, how much is this margin?
Thanks!
