iPAD mini 2 and BadElf question
Massimo Belloni
Massimo Belloni
Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)
Posts: 35, Visits: 6.5K
I may have access to a iPad mini 2 Wifi, which I could dedicate exclusively to SD use, so I have a counple of simple question:
  • Does anybody currently use a iPad mini 2? Is it powerful enough today to run SD? (in this case, does not matter if it is a wifi or a wifi+cell model, of course).
  • Being wifi only, it needs a GPS unit. I would like the BadElf 1008 (https://bad-elf.com/pages/be-gps-1008-detail), which connects directly to the iPAD, avoiding wireless connection. The question is: does anybody use this GPS with an iPAD? (iPAD model, in this case, does not matter) Does it feed correctly the position data so that SD works fine?
Many thanks in advance to all who will spend some time in replying.
Massimo Belloni
Edited 2/14/2019 11:19:30 AM by Massimo Belloni
George Reid
George Reid
Posts: 113, Visits: 1.6K
Massimo Belloni - 2/14/2019 11:18:52 AM
I use an Ipad mini 2 WiFi for Skydemon.  The device is perfectly able to run the latest version of Skydemon.  I get the GPS data into the Ipad by either of 2 means.  I can use Bluetooth to connect to a Garmin GLO receiver, or I can use WiFi to connect to my PilotAware system.  Both setups have proved to be reliable.
George E A Reid
PaulSS
P
Posts: 91, Visits: 3.2K
I had an old iPad (not a mini) that connected to my Bad Elf via Blue Tooth. It worked perfectly.
