Germany vertical boundaries information incomplete
As far as I can tell, everything is behaving as designed here.
EHOW flyer
EHOW flyer
Posts: 66, Visits: 215
Ah, I see what you mean! I have set (in Windows) that features will hide above 11000.
And indeed, there is a discrepancy between the graphical info (stack) and the textual info (right column).
derWessi
derWessi
Posts: 63, Visits: 157
EHOW flyer - 12/6/2018 12:34:16 PM
derWessi - 12/6/2018 12:23:42 PM
But in your case the airspace stack on the right is also missing the C airspace. Maybe you have enabled Automatic  Decluttering in your planing options?
No, the C airspace above FL100 is visible when pointing at the blue location and will disappear on the red location.
No, it's missing on the right of the popup window in both of your screenshots. So I guess you have enabled airspace decluttering (on android the option is in the map settings and called "automatische Vereinfachung" in German language).
 And the stack on the left depends on the size of the popup window. If the window is too small the airspace is not drawn.
EHOW flyer
EHOW flyer
Edited 12/6/2018 12:35:08 PM by EHOW flyer
derWessi
derWessi
Yep, that's exactly the problem I described here
The issue is that the graphical airspace stack depends on the size of the popup window. And the popup window size depends on the textual information shown on the right.
Regards,
Andreas
EHOW flyer
EHOW flyer
Have a check near EDFQ where the mentioned circle is just south of the RMZ (part of the notam circle is visible between these locations):
This is the stack when checked om the blue location, and
This is the stack at the red location.
The airspace stack at both locations should be the same.It seems that the stack is different if you check within a notamed area, restricted or prohibited area and in area’s with nothing specials. Outside. The stack shows less airspace, also no upper limit of the E-airspace, which is FL100 over total (?) Gernamy.
Edited 12/6/2018 12:35:54 PM by EHOW flyer
I just don't get it, sorry. At the point of the arrow in your screenshot I can't see any airspace other than the class E, which is accurately displayed in the tooltip.
EHOW flyer
EHOW flyer
derWessi - 12/3/2018 1:06:14 PM
I think this is a duplicate to this issue:
Maybe, but in this case there is a difference in the stack of the same airspaces but 'measured' on different locations.
derWessi
derWessi
EHOW flyer
EHOW flyer
Check the same airspace just inside the big circle and just outside the circle and you will see the difference. Ik looks that when the mouse points over an notamed area in Germany (check for some smaller circles) the airspace info is correct and outside it is incomplete, sometimes no info at all.
