GAR / Gendec
Michiel Verbeek
Michiel Verbeek
Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)Too Much Forum (248 reputation)
Posts: 3, Visits: 3
To keep administrative load to a minimum 😡 for travel from NL to UK you need to file a GAR and a Gendec. Not OR, but AND!
Now, for a route from NL to UK Skydemon does indeed warn you to file a GAR, as does it on the route back from UK to NL to file a Gendec. But what about the Gendec for the route NL-UK? It does not appear under the warning tap as far as I can see. Does SD generate a Gendec as well as a GAR?
Posts: 364, Visits: 2.6K
Michiel,
The latest UK requirements for a GAR can be viewed here:
As SemperFi mentioned a GENDEC is not required for arrival in the UK.
I presume the GENDEC is a NL requirement?
Tony
