SkyDemon Flight Planning
GAR / Gendec
http://forums.skydemon.aero/Topic26711.aspx
By tnowak
8/20/2018 7:40:19 AM
Michiel,
The latest UK requirements for a GAR can be viewed here:
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/724906/GAR_Instructions_July_2018.pdf
As SemperFi mentioned a GENDEC is not required for arrival in the UK.
I presume the GENDEC is a NL requirement?
Tony
By aeverbeek
8/19/2018 5:23:11 PM
To keep administrative load to a minimum 😡 for travel from NL to UK you need to file a GAR and a Gendec. Not OR, but AND!
Now, for a route from NL to UK Skydemon does indeed warn you to file a GAR, as does it on the route back from UK to NL to file a Gendec. But what about the Gendec for the route NL-UK? It does not appear under the warning tap as far as I can see. Does SD generate a Gendec as well as a GAR?
