Problems with power flarm portable
wrecker
wrecker
Posts: 21, Visits: 201
I am having problems with getting my power FLARM portable to connect through a "butterfly connect" to Skydemon ver 3.10.2 running on an I pad mini. It functioned perfectly for a year and has now stopped
The Ipad can see the output from the FLARM via the Butterfly device if I am not running SD ie it picks up GPS data.but SD cannot pick up either GPS or traffic data.
SD and the ipad function fine when using my backup GPS source.
Anyone any ideas?
TouchTheSky
T
Posts: 153, Visits: 4.6K
wrecker - 8/10/2018 10:12:45 AM
Anyone any ideas?
Through which App are you able to see output from the FLARM and which protocol is selected?
My quick guess is that you may have changed "Third Party Device" to something else than FLARM or the PIN has changed.
wrecker
wrecker
TouchTheSky - 8/10/2018 2:55:11 PM
Anyone any ideas?
The App is GPS Data and i was not aware of changing the PIN from the default
But i will check when next i go to the a/c
wrecker
wrecker
wrecker - 8/10/2018 7:08:53 PM
Anyone any ideas?
Well I think I have solved the problem I recently reset my password for my SD account and when i changed it to the new one on the Ipad for some reason it reset everything back to the default settings. It is worth noting that i have not changed my user name.
I wonder if Tim would care to comment if this is usual?
When you log in, SkyDemon loads your settings from your cloud storage, if you have previously saved settings there. Perhaps that is what happened.
