Diverting during VFR navigation flight
aircraft72
aircraft72
Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)
Posts: 8, Visits: 0
Hi there. I am using Apple I-Pad and Sky Demon latest version. During a VFR-flight i had to divert routing to the destination airport as my planed route was limited due to weather conditions.
So i thought i just gonna press with my fingers on the remaining leg and pull it to the new Waypoints. Done. But this way it was not possible. So i used the direct to button to my destination airport, but I still was not able to set Waypoints by “pulling” the leg.
Is the only way to do that during flight, to start planning a new route? I think, to delete and enter new waypoints, while flying, is not safe. There should be an easier way?
Any advise how to handle such case in a safe way during flight?
Gerhard66
G
Posts: 175, Visits: 358
RTFM ;-)
Just double-tap on the leg you want to change.
Happy diversions!
G.
aircraft72
aircraft72
Posts: 8, Visits: 0
OMG that easy Many tks Smile
g.bulj
g.bulj
Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)
Posts: 3, Visits: 6
or alternatively press the airfield you wish to divert to, press [Routing] and press [Route Direct]....
or alternatively press the SkyDemon icon (top left), press [Direct To] (brings up a list of airfields ordered by nearest first) and click on your diversion airfield...
Then you only have to touch the leg once and drag it to your waypoints...
Smile
Best regards
Dave S - G-BULJ
Edited 7/23/2018 1:25:55 PM by g.bulj
g.bulj
g.bulj
Posts: 3, Visits: 6
Gerhard66 - 7/20/2018 1:41:37 PM
RTFM ;-)
Happy diversions!
G.
Single tap ;-)
Best regards
Dave S - G-BULJ
