Feature Request : Radio Call Drill Down on Radio Tab
Robert Walker
R
Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)
Posts: 3, Visits: 0
Essentially proposing a drill-down reference tab under theradio tab selection. Now no excuse for poor RT but this would helpand educate early (and other!) pilots in correct RT calls and make more commonthe way GA interacts with ATCs etc given the prevalence of SD now so good PR too.
Calls would derive majority info from existing data in theapp so simple step to add reference calls card from this info.
Basically 4 headings : Request (ADDPAR) Call, Position Call, Mayday Call, (Practice) Pan Call similar to weather bar+info format
e.g. 'Request' in e.g. Green header bar
Norwich Radar
A - G-KEMC
D – Tibenham
D – Lowestoft
P – Hardwick
A – 2 Tousand feet
R – Request Basic Service
[Traffic / MATZ Penetration / ZoneTransit /  Joining Instructions / etc]
'Position' in Green header bar
Norwich Radar
A - G-KEMC
P – Hardwick
T – 05
L – 2 thousand feet
N – Lowestoft
E –15
'Mayday' in Red header bar
MAYDAY, MAYDAY, MAYDAY
C - Norwich Radar
A - G-KEMC
T – Motorglider
N – e.g. Damaged canopy
I – Landing in field
P – Near Hardwick, 2 thousand feet
P – NPPL
O – 2POB, Full Fuel
'(Practice) Pan' in header bar
(Practice) PAN PAN, PAN PAN, PANPAN
C – London Information
A - G-KEMC
T – Motorglider
P – NPPL
O – 2POB, Full Fuel
Possible thatcalls can be morphed/added to depending upon the station eg ATC v A/G protocol
Have mocked up a screen but can’t post the imageunfortunately.
Best,
Robert
Martin Bech
Martin Bech
Posts: 152, Visits: 352
Hi Robert
The feature is already there in SD. Just make your own dokument and transfer it to User Documents under the Airfield Tab.
I have several documents covering different procedures (stalles, flaps, landing Roll, .....). I have also documents/manuals for all the instruments in the aircraft under User Documents - so no need to take a lot of papers with you - SD have the information at hand👌
Robert Walker
R
Posts: 3, Visits: 0
Martin Bech - 7/7/2018 10:16:45 AM
Hi RobertThe feature is already there in SD. Just make your own dokument and transfer it to User Documents under the Airfield Tab.I have several documents covering different procedures (stalles, flaps, landing Roll, .....). I have also documents/manuals for all the instruments in the aircraft under User Documents - so no need to take a lot of papers with you - SD have the information at hand👌
Thanks a bunch for the reply  Martin I'll take a look at that cheers Robert
Posts: 8.1K, Visits: 9.3K
One problem that immediately suggests itself is that at least two of those call formats are UK specific.
