fuel tanks entry in PC version?
Paul Buckley
P
Posts: 32, Visits: 28
is the fuel tanks entry in the PC version (v3.9.5.0) somewhere, ie the ability to configure maximum and default fuel quantity for an aircraft. cannot find it in the same place as where it is in the iOS version (aircraft properties).  thank you. Paul
Posts: 626, Visits: 15K
Paul Buckley - 7/4/2018 3:26:22 PM
Click on the Aircraft button at the top of the screen, select the required aircraft, click on the Edit button and you will find what you are looking for under Weight & Balance.
Samsung Galaxy Tab A8 – Android 11.0 & SD 4.0.2.0
Huawei P30 – Android 11.0 & SD 4.0.2.0
5917, SD 4.0.2.0
Paul Buckley
P
Sky Painter - 7/5/2018 8:33:40 AM
aha, combined with the loading points in the PC version. thanks!
