+xis the fuel tanks entry in the PC version (v3.9.5.0) somewhere, ie the ability to configure maximum and default fuel quantity for an aircraft. cannot find it in the same place as where it is in the iOS version (aircraft properties). thank you. Paul
Click on the
Aircraft button at the top of the screen, select the required aircraft, click on the
Edit button and you will find what you are looking for under
Weight & Balance.
