TOC/TOD on log
Do you mean a log, or a planned route? Logs will contain detailed height readings and unless you're flying on autopilot these will naturally fluctuate a bit. You can therefore make your own judgment about when you reached TOC but SkyDemon will not attempt to label that point for you.
RobertMomsen
R
Posts: 2, Visits: 0
Hi all, can one add the TOC or TOD points onto the log automatically?
