Changing planned altitude for leg
Paul Buckley
P
Posts: 32, Visits: 28
Tim Dawson - 7/4/2018 10:42:05 AM
To bring up the leg properties, press and hold to get the What's Here menu and choose Leg Properties.
ok, extra step to before, but thanks.
Paul Buckley - 7/2/2018 2:07:44 PM
Sky Painter - 7/2/2018 8:15:19 AM
Paul Buckley - 7/1/2018 6:10:45 AM
Hi, it used to be that you could double click on a leg to change it's planned altitude e.g. to lower it to remain clear of CAS. It seems not possible to do this now with a later update? How do you now change the altitude of a specific leg please? Thank you. PauliPad 3.10.0.124
Double click, as opposed to double tap, suggests that you are talking about SD on a PC, but your signature mentions iPad, so I'm not clear which you are talking about.
Nevertheless, on PC, you can either double click the route leg to bring up Leg Properties or right click and then click on Leg Properties.
I'm not an iPad user, but assuming similar functionality to Android, in Planning Mode, double tap on the route leg to bring up the Leg Properties.
yes I was meaning iPad so OK double tap. this used to bring up the leg properties, like double clicking on the PC version, but now does not it seems.
can you still double tap to get leg properties on Android?
...can you still double tap to get leg properties on Android?
Yes. Sounds like a bug in the iPad version.
6396, SD 4.1.2
Paul Buckley
P
6396, SD 4.1.2
Paul Buckley
P
iPad 3.10.0.124
