Posts: 8.2K,
Visits: 9.6K
The problem is that your GPS device is occasionally reporting that you are at those coordinates. We do not attempt to filter such coordinates in SkyDemon, and so therefore the result is that your map will briefly flip to those coordinates (you may not notice this, if it's only brief) and they'll be entered in your log too. The solution is really to get a GPS that doesn't output non-sensical data.
