User waypoint in DD.decimal format?
If I type "32,23" into that box SkyDemon correctly interprets it as 32N 023E. Your region settings might be different from mine so you might need to use a semicolon or something to separate the two values.
maweb
m
Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)Too Much Forum (592 reputation)
Posts: 11, Visits: 2
Hi Tim
You just solved this riddle - thanks a lot :-)
It works for me with ”55,9876543;-9,8765432” using comma as the decimal seperator and semicolon as the latitude/longitude seperator.
This little change of seperators is no problem at all.
Excellent!
hcccs
h
Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)
Posts: 1, Visits: 1
Tim Dawson - 4/9/2018 2:02:51 PM
SkyDemon accepts most common formats for inputting waypoints, including the raw decimals separated by a comma or semicolon (depending on your locale). So we almost certainly already do what you're asking. If you can't get it working, let us know exactly what you're typing into which box and we'll get back to you.
I'm testing SD for the first time on my iPad and I'm trying to create a user waypoint. Under "Create User Waypoint" / Position I've tried various formats but none has worked. One format is 59.722, 17.717 but the Save button i disabled. This format works in EasyVfr4 so it should work here too. My locale is Sweden and language English.
Posts: 393, Visits: 2.6K
hcccs - 8/1/2025 11:22:20 AM
It works on PC Plan (Win 11), so maybe an IOS issue? I entered 51.000, -1.000 and it displayed on the map..
It will be a regional number formatting issue, as shown by another poster above. Possibly if you contact customer support they will know more.
