CAA GASCo Take Two campaign
Marks
M
Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)Too Much Forum (393 reputation)
Posts: 7, Visits: 8
To promote good vfr nav planning the CAA and GASCo are advocating a 2Nm mile lateral buffer from CAS. Seems sensible to me. Would it be worthwhile having a selectable ‘X mile’ buffer around the routeline or WPT that generates a planning caution? Sometimes it’s appropriate to fly close to CAS but I do see folks planning a gps glancing blow without much justification. This feature might help reduce some inadvertent airspace infringements.
Marks
M
Posts: 7, Visits: 8
http://airspacesafety.com/wp-content/uploads/2017/12/TAKE2_NWLAIT.pdf
Found the poster. Also advocating 200’ buffer vertical from CAS.
Marks
M
Posts: 7, Visits: 8
I sort of agree but it’s so easy to drag and drop with gay abandon that a ‘that might be a bad bad idea/ / you are breaching your pre defined buffers’ caution might encourage sound airmanship. It is a planning tool after all and my suggestion would be pilot selectable. Mindless GPS airspace infringements are on the up, so one could argue that the sage advice you rightly refer to isn’t being followed. I’m probably I’m the old fart category too and teach ‘old fashioned nav’ but also buy into technology aiding good practice- so long as it can be overridden after due consideration.
Edited 3/3/2018 5:44:15 PM by Marks
