Feature Request - Set zero wind
plume_tray
plume_tray
Posts: 116, Visits: 434
On iOS, when you go to Weather > Set Wind Conditons for Flight, you can manually enter the wind figures for all or individual legs.
It would be nice, if there was a button on that window to set wind to 000/00, rather than typing it.
Reason being, I often have to plan lots of flights in the future using still wind conditions (for example quoting for charter jobs many months ahead), and every time, I have to set wind conditions manually. Having a button to zero the wind would help by saving unnecessary key entry each time.
Alternatively, provide a wind toggle in the Weather drop-down, which would toggle between zero wind and actual/forecast wind.
Either way helps.
Posts: 8.2K, Visits: 9.5K
If you set your takeoff time in the future (which presumably is the case) SkyDemon will use zero wind. Are you not seeing that?
plume_tray
plume_tray
That's interesting, I never knew that. When I've checked the wind, it would always say auto unless changed manually so assumed it was getting wind data. Creating a route and reversing it does indeed prove it works.
How far in the future do you have to go before it uses zero wind?
Of course, I could set a date next week but it would be handy to know exactly how far ahead for future reference.
I think our wind forecast data goes out to around 24 hours ahead.
