Visits: 41
Hi all, I got a very strange behavior of my current Skydemon App 3.8.1.72 on my iPad. My setup consist of my iPad (4G) with the Skydemon App and the Pilotaware hardware. The Pilotaware device works as a WLAN hotspot in order to get my iPad connected to it. Skydemon works perfect (stable for years) when I choose the "location services" as a GPS source. Since I received my Pilotaware device, i configured the FLARM interface to get traffic information displayed within the moving map. This works also stable.
And now it get`s interesting :-) When the ipad gets pretty warm (sun shines on the display, 15 minutes are sufficient. Far away from thermal shutdown) , the Skydemon App crashes within seconds after choosing the "FLARM" source instead of the build in location services. The moving map screen is shown for about one or two seconds, traffic information is displayed. After that, the skydemon app is shutting down. After a restart, the FLARM configuration (e.g. the code) is missing sometimes.
When I restart the App, choose "go flying" again and the build in "location services", the Skydemon app run´s stable.
This is reproducible by 100%. I really don´t see an relationship why the Skydemon App crashes with a warm iPad with activated FLARM but run´s stable, when using the App without the FLARM option at the same temperature. Does anybode has a glue how to narrow down this problem? Are there any logs I can check?
Greetings from Germany, Henrik
