Visits: 98
Same here. I'm seeing an Amber warning that says 'Wind data is not available for the complete journey.' and the wind speeds are set to zero in PLOG. TAFs and METARS seem OK on the map though.
While I'm at it, could I suggest an enhancement? I was using an existing route which was weathered off a few months ago. The NOTAMS were unusual, only showing multiple ATZ activation notices for the destination. None of the usual NOTAMS were shown on the map. This caused some head scratching until I realized the take-off time was set to last October. Hardly surprising no NOTAMS then. However, it might be a good idea to throw up some kind of warning if the takeoff time is set in the past as it's quite easy to recycle favourite routes and miss this subtle point, particularly as NOTAMS covering the period in past do appear in the briefing.
'Warning, your take-off time is in the past, any NOTAMS issued after that time will not be present in the briefing'
