Goto improvements
athiele
athiele
Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)
Posts: 4, Visits: 16
I'd like if the got‌o function could be improved.
At the moment I get a list of nearest ai‌rports or waypoints on my flightplan.
Could that be ex‌tended by a list of nearest VORs and NDBs. Even IFR intersections that are in your charts would be worth to be shortlistet.
It would help a lot if you can reselect the last goto once more. If you got once and have to make a big turn you would have to intercept the course line. In most cases it would be enough to goto to the same point one more to get a new line.
Andreas‌‌
athiele
athiele
athiele - 5/13/2017 1:09:03 PM
Andreas‌‌
Really no one interested in an improved direct to function?
athiele
athiele
Well, you can go direct to "nearby airfields" and "turning points".
I'd like this fun‌ction for VORs, NDBs and other waypoints too.
The find function with‌‌ uppercase for identifiers is much to complicated in flight.
athiele - 6/2/2017 12:48:06 PM
You could always tap and hold on your chosen VOR, NDB etc to bring up the What's Here pop-up then tap on the VOR/NDB name and you will be presented with a number of options, one of which is Route Direct.
6396, SD 4.1.2
athiele
athiele
Yes, if it is in the range of the current display. But why not the easy way as for airports?
Second  pro‌posal was to have a simple way to repeat the last direct to.
