By athiele - 5/13/2017 1:09:03 PM
Hello, I'd like if the goto function could be improved. At the moment I get a list of nearest airports or waypoints on my flightplan. Could that be extended by a list of nearest VORs and NDBs. Even IFR intersections that are in your charts would be worth to be shortlistet. It would help a lot if you can reselect the last goto once more. If you got once and have to make a big turn you would have to intercept the course line. In most cases it would be enough to goto to the same point one more to get a new line. Thanks Andreas
By athiele - 6/3/2017 3:18:25 PM
Yes, if it is in the range of the current display. But why not the easy way as for airports? Second proposal was to have a simple way to repeat the last direct to.
