Logging and/or flight time not calculated correctly
Prev
1
2
Jump To Page
jokoenig
jokoenig
posted 4/2/2017 7:14:15 PM
HOT
Visits: 33
When reading the log, skydemon sometimes calculated the flight and or log times inaccurately. Attached you see a picture where this happened for the log time, it can happen for the flight time also.
You see that the time from log start to log stop should be 1:40, however it says 1:39. I assume, this is because the log started e.g. at 13:59:59 Z and stopped at 15:39:01 Z. So technically, the program calcuted the times correctly. However, nobody works like that. When I write the log start/stop times (which equal block times in my case) into my personal flight book, I need to know the minutes in between.
So, please make the software to work precisely on the minute, not on the second.
Regards,
Johnny
Prev
1
2
Jump To Page
