Keep the "Map"-Window and virtual radar window synchronized
drnicolas
drnicolas
Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)
Posts: 99, Visits: 114
Maybe I am doing somethinng wrong:
As I zoom‌ the map-window in, the virtual radar seems not to zoom in or out accordingly.
Today‌ I wanted to see the complex airspace-structure somewhere in Belgium where the "What's here" feature gave me 6 or 7 items.
Hard to find the correct place in virtual radar according‌ to "What's here".
The corresponding üplace should be automatically marked in virtual radar and vice versa.
That would helpl a lot.
Edit: the Problem seems to be only half. Of course, you can tap long ‌‌‌on a Location in virtual Radar and the according Location in map window gets highlighted with a yellow circle. Also in virtual Radar i can see a distance Information.
But this seems not to to work from the map window‌.
I would love to see the complete "stack" of restricted Areas at certain locations‌
Edited 12/18/2016 9:07:09 PM by drnicolas
It cannot work the other way around because only positions directly on the route can appear in virtual radar. And even then, they can appear in virtual radar twice or more times if your route comes back on itself.
Use the Map Ruler functionality if you want to quickly see the stack of airspace at any location on the map. On iOS you can activate this by holding down two fingers, and Virtual Radar will immediately update to show the cross-section between your fingers.‌
