Maximum Licences
G-OIBM
G-OIBM
Posts: 71, Visits: 946
Tim Dawson - 12/12/2016 10:59:33 AM
Nope, it's two PCs and two mobile devices (iOS or Android).
So to clarify - when you say 2 PCs - are we talking Windows OS only PCs or can the 2 PC's be iMac based (apple).  If it's the latter, then something is wrong with the licence checking; another user O know also has the same issue as myself - described above.
Hugh
G-OIBM
Commander 114
G-OIBM
G-OIBM
Shifu - 12/11/2016 7:44:06 AM
AFAIK it is 2 mobile and two computer licenses, so nothing changes going from PC/Win to Apple/macOS. Running a virtual machine will give you the full SD Plan as well, once you get tired of the Wine-wrapped version.
I'm tending to think its not 2 mobile and 2 computer licenses as I definitely can't run SkyDemon on more than 2 Apple based machines.  I have a MacBook Pro, iMac desktop, iPad Mini and iPad 2.
I‌f I do the usual log out and log back in again - it works for that device but locks me out on the '3rd' device.‌
Hugh
G-OIBM
Commander 114
G-OIBM
G-OIBM
I've just finished fully moving to the dark side by ditching the PC stuff in favour of Apple (iMac, Macbook, iPad etc.).
T‌he great work done to get Mac versions of Skydemon is much appreciated and I have no issues running using Sierra OS.
T‌he snag that I have now is that I run out of licences to use Skydemon across all 4 of my Apple platforms as the current setup with SkyDemon (and correct me if I'm wrong) allows for 2 Apple Products and 2 PC products; this was fine when I had the mix of PCs and Apple, but not since I've migrated to wholly Apple.
T‌im - Is there any way you can tweak the licence checks to allow 4 uses on any combination of operating systems?
M‌any thanks‌‌‌‌
Hugh
G-OIBM
Commander 114
