Problem with VFR charts integration on moving map (France)
Martin Bech
Martin Bech
Posts: 152, Visits: 352
Ahrrrrr -.....if there is a plate or other info from AIP...??
If you don't want to download all plates, then do not perform a download all. I'm sorry but we can't really filter the downloads as we are not in charge of naming or categorising the documents (that's up to individual countries).
Martin Bech
Martin Bech
Thanks Tim - I will contact Naviair who is responsible for Danish AIP
condor4
c
Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)Too Much Forum (297 reputation)
Posts: 3, Visits: 0
I‌ do seem to have the same issue as the threadstarter.
I‌t occures during planning mode when I try to display the georeferenced map‌‌. If I swipe the map parts of the plates do briefly appear and are then overlayed by the map.
In simulation mode the plates don't even appear. If' tried that with Colmar in France and LOWI-Innsbruck in Austria.
V‌ersion is 3.7.1 (Trial-Version) on a Samsung Galaxy S6 with the latest Android-Build.
K‌ind regards,
S‌ebastian‌
That doesn't sound like the same issue as the original poster. From what you wrote I don't understand what is happening, though. You might like to call our support, or describe here in greater detail exactly what you are doing.
condor4
c
Posts: 3, Visits: 0
Tim Dawson - 1/13/2017 10:44:44 AM
That's what it looks like while I'm swiping and as soon as I let go of the display the plate disappears and the only part of the plate left is the red "X" button over the vector chart.
I think what you are describing is a bug in the latest Android version which is affecting some people. We plan to push out a version later today which resolves the issue; hopefully this will help.
condor4
c
Posts: 3, Visits: 0
Tim Dawson - 1/13/2017 4:00:35 PM
Thank you for your reply!
