GDL90 Support
DavidC
DavidC
Posts: 23, Visits: 30
Good to see this added in the latest release, which shows up as an alternative choice to FLARM, XPlane and SkyView.
Couple of questions:
1) W‌hich features of the protocol are supported?
I‌'m assuming it would mainly be traffic reports so could display any nearby aircraft that it knows about, which could include those reported from ADS-B groundstations in the US using TIS-B. But would it support METAR, TAF or NEXRAD weather information (if flying in the US, and can receive it through FIS-B via the UAT frequency)? Not relevant elsewhere, so I could understand if you didn't.
2) D‌oes this require the GDL90 compatible device to become the GPS position source, instead of the tablet's built-in GPS? If that is the case, it could act as GPS source without ever reporting any other traffic.
I found an old (2007) copy of the GDL90 protocol specification here
https://www.faa.gov/nextgen/programs/adsb/Archival/media/GDL90_Public_ICD_RevA.PDF
T‌hanks‌
‌‌‌EDIT: I'm using version 3.7.0.58 on an Apple iPad 4
--- CPL/IR/FI based in South of England
Edited 11/28/2016 7:09:16 PM by DavidC
1. Traffic and ownship position (i.e. GPS)
2. Yes‌
Tommi
T
Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)
Posts: 1, Visits: 0
Hi!
uavionix pingBuddy does not have GPS built in. Can it be used in Sky Demon (iPad mini) with external GPS receiver?
If not, will this device be compatible with SD at some point?
-Tommi
That device cannot currently be used. We will evaluate this going forward if there is significant demand for it. Bear in mind that it has no barometer, so (I believe) it is not possible to tell accurately the height difference between ownship and other traffic.
TFinken
TFinken
Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)Too Much Forum (741 reputation)
Posts: 5, Visits: 13
can the GARM‌‌IN GDL39 or GDL39 3D beused to display traffic with SkyDemon?
Best regards,
Thorben‌‌‌
No; at present Garmin do not wish to work with other companies in Europe in that way.
giannisd
giannisd
Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)
Posts: 100, Visits: 181
Tim Dawson - 4/18/2017 11:39:48 AM
You may consider the Air Avionics alternative to display traffic : TRX and Air Connect,
http://www.air-avionics.com/air/index.php/en/
regards,
‌Gianni ‌‌
