Virtual Radar weather while flying
RobertPBham
RobertPBham
Posts: 14, Visits: 14
Hi there,
When you are planning a flight, the virtual radar displays weather information and cloud height.
However, when flying all of this information disappears. I can see when I'm flying that I receive new METAR information but the virtual radar never updates with any weather and cloud height information. Is there a setting I have missed or is it just not designed to do that?
Rob
RobertPBham
RobertPBham
Hi Shifu,
Thanks - that could be it! I've enabled it now and will see if everything appears when I fly next.
Thanks for your help
Rob
That will re-enable the display of weather information on the map, but virtual radar is quite different. You get an entirely different instrument when you're flying than when you're planning, though on the face of it they look similar. The navigation virtual radar is not designed to show weather at all. The reasoning is this: virtual radar shows only what's coming in the ten minutes directly ahead of you. We don't think we would add much value by showing cloud layers etc on there, which you should be able to see simply by looking outside of the cockpit.
RobertPBham
RobertPBham
That makes perfect sense - didn't realise that it was only showing the next ten minutes - it does explain why I couldn't scroll ahead when looking for terrain height and obstacles when I was flying! :-)
Rob
Europaflyer
Europaflyer
Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)
Posts: 2, Visits: 8
RobertPBham - 9/18/2016 12:51:45 PM
Hi there,
Rob
