3.6.4 Flight Logs
BobD
BobD
Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)Too Much Forum (567 reputation)
Posts: 10, Visits: 28
I was just reviewing a flight log from today, when I was offered the upgrade to this latest version, so I downloaded it. I like the option to print out the log details, but the facility to hover over the line of the flight log on the main screen no longer seems to display the speed/high on any portion of the flight. I found this useful to analyse my approach profiles. Has this option gone for good, or am I missing something ?
I am looking at a flight log imported from Android to my PC running W10.
Edited 9/15/2016 5:27:12 PM by BobD
FaRu1
FaRu1
Posts: 35, Visits: 47
BobD - 9/15/2016 5:23:16 PM
You can still move the plane symbol on the virtual radar screen. The plane symbol will then be displayed on the main screen accordingly.
Posts: 8.1K, Visits: 9.4K
You're quite right; this little bit of functionality had got lost when we unified the analysis virtual radar code between our platforms recently. We will add it back for the next version. The above poster is correct, though; the platform-independent way of inspecting your flight log is to drag the little aircraft symbol around.
BobD
BobD
Thanks for the two responses and the tip about using the little plane in the Virtual Radar/Flight Log. Just another small problem with this, and I don't know if it is limited to W10, but the information box when dragging the plane, is not deep enough to display the bottom lines of information, so the height & speed below the time is mostly obscured
Yes, this is another bug we have picked up and fixed ready for the 3.6.5 release. Thanks.
