SkyDemon Flight Planning
Supplementary information in ATS flight plan
kjep
kjep
posted 9/9/2016 10:30:08 AM
Visits: 11
Dear SkyDemon,
I have some questions and comments about how you send supplementary information in your ATS flight plans. This is compared to what I see at work as a controller, in flight plans coming from more conventional sources.
1) You put pilot name and phone number after the RMK/ switch in field 18. This would normally go in field 19 after the C/ switch and not transmitted in the regular flight plan to ATS. Should this information be needed, we simply request it from the originator.
2) Also in field 18 RMK/ you add "SUPP INFO RQS KBLIHAEX". There is an ORGN/ switch defined for this, why not use that?
https://contentzone.eurocontrol.int/FPL/item.aspx?id=180
3) "CREATED BY SKYDEMON". This feels like some email clients adding a "Sent from my iPhone" to the signature. It shouldn't be there, nobody cares. IMHO it makes you look amateurish...
Sorry to come off sounding negative. You have a great product, I use it all the time when I fly. Please consider this suggestions to make it even better.
Johan
Threaded View
Threaded View
kjep
The reasons that SkyDemon flightplans are the way they are have...
9/9/2016 3:50:08 PM
