Chart loading in mobile
Baron von Mildred
Baron von Mildred
Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)
Posts: 78, Visits: 176
I found that when flying from one country to another the chart would not load for the upcoming country, even when flying through it! I just ended up flying through blue until I returned to the first country! The charts are all installed on the sd card.
Posts: 593, Visits: 4.9K
That's not normal behaviour!
Baron von Mildred
Baron von Mildred
Just a thought, does anyone know if it is the land border or the FIR that triggers the next chart upload? Sometimes the land & FIR borders do not coincide!
Baron von Mildred
Baron von Mildred
It's usually the FIR border with some notable exceptions, for example if you're within the channel islands class A that's considered to be both UK and French chart coverage. The chart load is triggered when you're about 10 minutes from the border of chart coverage.
Baron von Mildred
Baron von Mildred
So, where FIRs & land borders don't line up it may be necessary to force load a chart?
It should never be necessary to force-load a chart during normal flying. If you give me an example of where you mean, I can give you a definite answer.
Baron von Mildred
Baron von Mildred
For example a flight from FLND to FLMA?
For our African charts the FIR boundary will be where charts are switched.
Edited 6/23/2011 7:51:29 PM by Tim Dawson
