How to deactivate the High-Resolution Terrain Data
Björn
B
Posts: 10, Visits: 75
i activated the High-Resolution Terrain Data. How to deactivate this function at my devices?
Björn
George Reid
George Reid
Posts: 113, Visits: 1.6K
When you select High Resolution Terrain data, a number of files with a ".HGT" extension are downloaded and stored on your device.  You cannot deactivate the High Resolution Terrain.  If you no longer require that terrain you need to remove the HGT files from your device.
On Android devices you need to navigate to the folder containing the HGT files and manually delete them.
On IOS devices it is not possible to delete data files.  You need to uninstall the SD application and then re-install it  (remember to save routes, aircraft, settings, logs to the cloud first)
George E A Reid
Can you briefly explain why you no longer wish to have high-resolution terrain data?
Björn
B
Tim Dawson - 8/24/2016 11:55:24 AM
Hello SD-Team,
the map scroll speed is not very fast at my iPad4. So, i removed the high-resolution, deactivated the railroad-tracks. After that, the map rebuilding is nice fast.
At my iPhone 6 Plus, everything is ok. Only the iPad4 :-(
High-resolution terrain data does not affect map scroll speed whatsoever. Only the first time it is shown, the terrain is built; just the save as low-resolution terrain data. It is then cached and there's no difference in tile load speed between low-resolution and high-resolution.
You can delete the HGT files on you iPad using a custom file explorer for iOS. There's a number of them available, some even for free.
Björn
B
Tim Dawson - 8/25/2016 11:29:17 AM
Hello Tim,
you are right. It takes no sense. I deactivated the terrain relief. Now, my old iPad is fast.
