Visits: 149
Hi Dave,
I think you may be getting 2 functions confused.
If you connect your Skymap and download your 'track' from your Skymap to SkyDemon, then once it is downloaded, you can then use the 'export to file' to save your 'track' as a GPX file.
If you create a 'route' within SkyDemon, then you can use the 'Save As' function under the ROUTE menu to save the 'route' as a GPX file, which you should then be able to load in to your Skymap.
Hope that helps.
Dom
