Flight Log Track Not Exporting To GPX
http://forums.skydemon.aero/Topic1955.aspx
By Domwilko - 2/12/2011 7:54:37 PM
Today I used Version 2.0 for a flight from Kemble to Turweston and it worked well.
After my flight, I always sync my mobile device to SD Planner. In the past I'm sure I've been able to then save the track as a GPX file so that I can upload it to Everytrial.com, so that others can take a look at where I've been flying.
Tonight I've tried to save my track as a GPX file, but the file appears to be empty!
Am I going mad and has this never worked or is there an issue with saving tracks as GPX files?
By Domwilko - 3/27/2011 9:40:17 AM
Hi Dave,
I think you may be getting 2 functions confused.
If you connect your Skymap and download your 'track' from your Skymap to SkyDemon, then once it is downloaded, you can then use the 'export to file' to save your 'track' as a GPX file.
If you create a 'route' within SkyDemon, then you can use the 'Save As' function under the ROUTE menu to save the 'route' as a GPX file, which you should then be able to load in to your Skymap.
Hope that helps.
Dom
